Start application minimized.
Discussion in 'Android' started by tehownt, Sep 27, 2010.
  1. tehownt
    Aug 7, 2010
    I'm using 3cx phone on Android with the Tasker application, so that it gets automatically launched whenever certain criteria are met, but I wanted to know whether there was a possibility to add command-line parameters at application launch in order to have it start minimized (in background with the status icon only).
    Otherwise, is there any plans to add this as a functionnality of the softphone ?
    On another note, are there plans to support different ringtones than the default/iPhone one ?
    Thanks.
    --tehownt
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    There are currently no plans to add such a feature in the 3CXPhone for Android.
    As it is a free client, we are working on making it work for as many devices as possible with minimal bugs.
    Feature requests / adding features is not something we are doing at the moment i'm afraid...
    Fixing the main issues of the 3CXPhone is our highest priority.
