Solved Start call recording from Managers Phone / Soft console
Discussion in '3CX Phone System - General' started by Sean Glasspool, Feb 13, 2018.
  1. Sean Glasspool
    Dec 7, 2017
    40
    Greetings!
    First time posting, please be gentle :)
    Is it possible for another user with the relevant permissions to start recording another users call.
    Lets assume a manager hears a call going on and thinks that the call should be recorded for what ever the reason.
    I have had a look through the docs, but wasnt able to find the answer.
    Thanks in advance!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @Sean Glasspool
    This is currently possible only via the Web clients switchboard and given that the extension has the appropriate rights to do so. You should see the ongoing call on the switchboard and by right clicking on it you should see all the available options
  3. Sean Glasspool
    Dec 7, 2017
    40
    Many thanks for the reply. I will re-test this and see if it does what I need it to do.
  4. Sean Glasspool
    Dec 7, 2017
    40
    Im not sure what other rights I can assign to make this work.
    example, I have set up an extn as a Manager and then ticked all the various options under Rights.
    When a user is on a call any options from the web client dissapear.
  5. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Make sure that the extension is a manager to the correct group as different groups have different rights. Assuming that you have an extension as manager for the correct group of extensions then when you navigate to the web clients switchboard and right click on the conversation you should get the following options:
    Sean Glasspool likes this.
  6. Sean Glasspool
    Dec 7, 2017
    40
    Ah - I see. Perfect. My knowledge gap has been filled. :)
  7. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Glad i could help :)
