Start Exchange sync manually?
Discussion in '3CX Phone System - General' started by lsteger, Mar 31, 2015.
  1. lsteger
    Mar 31, 2015
    5
    Hi there :)
    Is there a way to start a Exchange sync manually instead of waiting until the automatic sync at 4:00 am?
    Lorenz
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    In order to trigger the sync you can also restart service 3CX PhoneSystem Company Directory.
  3. lsteger
    Mar 31, 2015
    5
    OK, thanks a lot :)
