Starting 3CX after reboot???
Discussion in '3CX Phone System - General' started by getintechtom, Oct 29, 2016.
  1. getintechtom
    Oct 29, 2016
    Hi all,
    I finished setting up a virtual machine for 3CX and it required a reboot. I lost connection to the portal site after the machine came back online.
    What are the debian commands to start the 3CX service backup so I can continue programming?
    I check the Admin doc but it's online for the first time install.
    Thanks,
    Thomas
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I have to infer you describe the ISO install.. yes?
    Else, the chronology wouldn't make sense.. the sequence would be machine build, then 3CX install, then 3CX config.
    I haven't looked at it yet, but my machine is running Jessie, the services are in systemd.
    systemctl | grep 3CX should list out the required services.. all should be loaded active running.
    However, I'm not certain where the ISO-based install leaves the state of things.. I'd expect it to begin with the config site and/or tool.
