Static and all sorts of noise when in call.
Discussion in 'Windows' started by mutti_wilson, Jul 16, 2008.
  1. mutti_wilson
    May 2, 2008
    53
    I am using the latest version of both the server and the client and making calls over a PSTN line via 3cx Softphone tunnel. I am doing some testing with leaving my voicemail greeting and voicemails on other phones and all the sound I can make is static, humming, all sorts of racket. The sound I hear (voicemail greetings and system prompts are clear as a bell, it's only my voice that is messed up.
  2. mutti_wilson
    May 2, 2008
    53
    It was my mic. Something was jacked up, fixed now.
