KerryG said:You can define the range within your DHCP scope depending on which DHCP server you are using. You can set the DHCP server to hand out reservations based on the mac address of the phone. That said, I usually don't setup reservations or static ips on the phones. Always seems like its more work than its worth.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
