Statis vs. dhcp for ip phones
Discussion in '3CX Phone System - General' started by abelaguilar, Dec 13, 2007.
  1. abelaguilar
    Nov 4, 2007
    94
    Wondering if I should assign a static ip to my polycom phones or let them pick up an ip address on their own. Which creates a more stable network?
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    As long as you have DHCP i cant see no harm let it stay that way if your phone supports it.
    3CX box should indeed have static IP for registration purposes.
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Assuming you have set the options correctly, and that the devices follow the RFC, then there is no difference between static and DHCP for network stability.
    I once did 2.5 years solidly on a DHCP rollout project for 250,000 clients on a network, so I can go all anal about it if you need :)
    Cheers,
    Mike.
  4. abelaguilar
    Nov 4, 2007
    94
    awesome thanks. i'll leave it as dhcp and keep things simple.
