Status Log
Discussion in 'Ideas' started by ZANONI Jean-Claude, Feb 19, 2018.
  1. ZANONI Jean-Claude
    Sep 13, 2017
    24
    Dear support,
    It should be grate to find in the log the status log off an exention, with date and hours when the status change and witch state was applied.
    (hope you anderstand i'm french, sorry for my english)
    Best regards.
    naveensenapathy likes this.
  2. voiptoys
    voiptoys Member
    Feb 13, 2013
    478
    79
    I don't know if there is a 3CX report, somewhere, that provides this information. However, this information can be found in the table callcent_ag_queuestatus table. Here is a sample:
    q_num, ag_num, timeofupdate, is_loggedin_in_queue, is_loggedin_in_allqueues
    804 116 2017-05-30 22:11:30.000 False False
    804 116 2017-05-30 22:12:22.000 False False
    804 116 2017-05-30 22:15:13.000 False False
    804 116 2017-05-30 22:15:13.000 True False
    804 116 2017-06-01 05:17:40.000 False False
    804 116 2017-06-01 05:17:41.000 False False
    804 116 2017-06-01 05:19:31.000 False False
    3CX strongly discourages accessing the database directly (that's an understatement). Unless you are very, very careful you can place locks on whole tables by accessing this data, which could cause 3CX to crash. Support could also flag your PBX as unsupported.
