Discussion in '3CX Phone System - General' started by eclipse2000, Jun 12, 2011.
  1. eclipse2000
    Feb 3, 2011
    31
    When using the 3CX client on extensions i get the colum up on the right hand side showing all extensions on the system which is fine and i can call them no problems.
    At the side of each extension is a grey dot which i i would imagine is the status so i would expect this to show green or red.
    Am i right in thinking this, if so what could be the cause of the colours not showing.
    Thnaks
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    I assume you are using the Free Edition of 3CX? if so this is why, they only work in the paid versions of 3CX Phone System.
