stay on call after transfer
Discussion in '3CX Phone System - General' started by Cynthia Slade, Sep 13, 2012.
  1. Cynthia Slade
    Mar 22, 2012
    45
    Using 3CX V10 or V11 is there a way to transfer an incoming call to an external number and stay on the line for a minute or two? example: call comes in, recpt transfers call to outside vendor, recpt explains to vendor the reason she transfered call and then disconnects leaving outside vendor and call speaking to eachother.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
  3. Cynthia Slade
    Mar 22, 2012
    45
    This is not the solution we need. We need a "3-way" call allowing the transfering party to disconnect. An attended transfer disconnects the transfering party when it connects the other two lines.
  4. Cynthia Slade
    Mar 22, 2012
    45
    Sy I forgot to thank you for your post - Didn't mean to be rude
  5. SY
    3CX Support
    Jan 26, 2007
    1,825
    Are you looking for conference?
  6. Cynthia Slade
    Mar 22, 2012
    45
    Hi Sy No conference will not work for the same reason - if the orginator of the conference hangs up the other callers are disconnected. What our client would like is when they get an incoming call and they need to transfer the call to an external number (a vendor or parts company) they would like the abiliity to stay on the line and make sure the caller is actually connected to the correct person/dept at the vendor or parts company before they hang up.
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    Do you mean that "Attended transfer" does not deliver call to proper person? :shock:
  8. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I think he means he wants to be able to stay on the line with the incoming caller while the external number rings and have a 3way conversation when the external number is answered.
    I don't think there is a direct way to do this with 3cx however I just had a thought, I have not tried this so don't know if it will work. If you use 3cx MyPhone couldn't you do an attended (or blind) transfer then as soon as you have made the connection between the incoming and external number right click on that call in MyPhone and Barge in on it? Just thinking here so it would be something like...if you were quick you should join the call befor the external number even answered.
    Answer incoming call,
    Press Transfer
    Dial external number
    press transfer
    right click call in 3cx Myphone
    click Barge in.
    Hmmm, I'll have to give it a try
  9. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I can see the use for this, you need to transfer a caller to an outside number (vendor, service dept. etc) but you want to make sure they get to the right person and you also have a need for 3 way communication that you can drop out of while leaving the other two connected.
    Using Yealink phone and having 3CX MyPhone installed on computer.
    Press Transfer
    press transfer
    click Barge in.
    Just tested as described above and it does work, maybe not the best way but it does allows three way conversation.
  10. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Gschwab-
    I think the question then becomes-
    The 3 way was done, you have now connected the remote party to the person/dept. needed, can you now drop off the call so that the other two can continue?
    In your just completed test, you never indicated that you dropped off and were successful in leaving the other two parties connected. You stopped at barge in.
    Can you advise further?
  11. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    i suppose Cynthia speak about possible path replacement ( anti tromboning) after call transfer external-to-external is completed
  12. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Correct, I was able to transfer an incoming call to an outside number, "barge In" and have a 3 way conversation and then disconnect and the other two were able to continue after I dropped out.
  13. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Yes , but after transfer how many external channel have busy ??
    1. incoming call to 3cx
    2. outgoing from 3cx to external destination
    In this case you have two channel busy for one conversation
    Path replacement ( using refer ) must release channel after perform transfer , and incoming call speak to outgoing call without pass via 3cx .
    Example Patton Media Gateway use ECT ( explicity call transfer ) where it release channel , but is important carrier is able to accept it .
  14. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    That would be something to keep in mind depending on your system, ie: sip trunks, PSTN, etc.
    Here I use a paid version of 3CX with 8 consecutive call license and a NexVortex sip trunk which allows unlimited call paths, I have only 8 extensions, and only 4 of them are in regular use so I have room to grow and don't need to worry about running into the license limitation. If and when I do start to use a higher call volume I'll simply upgrade to a larger license....money well spent in my book.
  15. lneblett
    Sep 7, 2010
    2,061
    56
    George -
    Thanks, nice to know.
