Sticky 3CX-Window
Discussion in 'Ideas' started by HOFA, Oct 22, 2015.
  1. HOFA
    Oct 21, 2015
    we are using 3CX since a few days and it´s a really good and useful software!
    But we are missing a feature, our former software had:
    A window or widget, which sticks/docks to edge of the screen. This window needs to incluce all important features of 3CX and it should always be on the foreground. This makes the workflow much comfortable and faster.
    We are really missing that!
    All the best :)
    Jan
