- Joined
- Dec 1, 2007
- Messages
- 28
- Reaction score
- 0
I installed build 664 hopping that the DR transfer issue had been resolved. The transfer fails going from the DR to the extensions. Here is the log: (lines 8 & 9 show the failure)
Thanks.
Code:
Time Function Message
19:48:09.055 Call::Terminate [CM503008]: Call(8): Call is terminated
19:48:08.993 Call::Terminate [CM503008]: Call(8): Call is terminated
19:48:08.962 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
19:48:01.715 Call::Terminate [CM503008]: Call(9): Call is terminated
19:48:01.636 Call::Terminate [CM503008]: Call(9): Call is terminated
19:48:00.699 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
19:48:00.684 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
19:48:00.684 Call::RouteFailed [CM503015]: Call(9): Attempt to reach [sip:[email protected]:5060?[Replaces=ZTAxNDllZjE1Mjc3ZmEzNGU3MmEwMTE2NTc5ZjI5MzA.%3Bto-tag%3Ddf1f937a%3Bfrom-tag%3D46441562];tag=df1f937a failed. Reason: Not Implemented
19:48:00.684 CallLeg::onFailure [CM503003]: Call(9): Call to sip:[email protected]:5060 has failed; Cause: 501 Not Implemented; warning: INVITE+Replaces is not supported yet!; from IP:192.168.16.20:5060
19:48:00.137 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
19:47:59.934 CallCtrl::onLegConnected [CM503007]: Call(9): Device joined: sip:[email protected]:40600;rinstance=37480718307db95c
19:47:59.903 CallCtrl::onLegConnected [CM503007]: Call(9): Device joined: sip:[email protected]:40600;rinstance=cb2c955d1a4ee538
19:47:59.903 Extension::printEndpointInfo [CM505001]: Ext.999: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX MakeCall helper] Transport: [sip:127.0.0.1:5060]
19:47:59.903 CallCtrl::onAnsweredCall [CM503002]: Call(9): Alerting sip:[email protected]:40600;rinstance=37480718307db95c
19:47:59.372 CallCtrl::onRerouteReq [CM503005]: Call(9): Forwarding: Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=37480718307db95c]
19:47:44.643 Extension::printEndpointInfo [CM505001]: Ext.213: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [PolycomSoundPointIP-SPIP_430-UA/1.6.7.0133] Transport: [sip:192.168.16.20:5060]
19:47:44.627 CallCtrl::onAnsweredCall [CM503002]: Call(9): Alerting sip:[email protected]
19:47:44.221 CallCtrl::onSelectRouteReq [CM503004]: Call(9): Calling: Ext:Ext.213@[Dev:sip:[email protected]]
19:47:44.221 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]:5060]
19:47:44.221 Extension::printEndpointInfo [CM505001]: Ext.515: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
19:47:44.128 CallCtrl::onIncomingCall [CM503001]: Call(9): Incoming call from Ext.515 to [sip:[email protected]:5060]
19:47:39.567 MediaServerReporting::DTMFhandler [MS211000] C:8.1: 192.168.16.143:6000 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
19:47:29.024 CallCtrl::onLegConnected [CM503007]: Call(8): Device joined: sip:[email protected]:40600;rinstance=cb2c955d1a4ee538
19:47:29.024 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
19:47:28.977 CallCtrl::onLegConnected [CM503007]: Call(8): Device joined: sip:[email protected]
19:47:28.977 Extension::printEndpointInfo [CM505001]: Ext.515: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
19:47:28.977 CallCtrl::onAnsweredCall [CM503002]: Call(8): Alerting sip:[email protected]:40600;rinstance=cb2c955d1a4ee538
19:47:28.431 CallCtrl::onSelectRouteReq [CM503004]: Call(8): Calling: Ext:Ext.515@[Dev:sip:[email protected]:40600;rinstance=cb2c955d1a4ee538]
19:47:28.431 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]:5060]
19:47:28.431 Line::printEndpointInfo [CM505002]: Gateway:[AudioCodes 11] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-MP-118 FXO/v.5.00A.024] Transport: [sip:192.168.16.20:5060]
19:47:28.431 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
19:47:28.321 CallCtrl::onIncomingCall [CM503001]: Call(8): Incoming call from 9419324501@(Ln.10800@AudioCodes 11) to [sip:[email protected]:5060]
19:47:28.321 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10800 forwards to DN:515
Thanks.
