Still no onbound
Discussion in '3CX Phone System - General' started by alex_omega, Mar 15, 2008.
  1. alex_omega
    Mar 10, 2008
    5
    Here is my debuglog from patton for a incomming call:
    INVITE sip:10006@192.168.1.87 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.59:5060;branch=z9hG4bKa0407c240
    Max-Forwards: 70
    Content-Length: 218
    To: sip:553@192.168.1.87
    Call-ID: b297eb66d0bf413e49f2dff18e31e366@192.168.1.87
    CSeq: 1713200681 INVITE
    Route: <sip:192.168.1.87;lr>
    Supported: timer
    Remote-Party-ID: <sip:553@192.168.1.87>;party=called
    Content-Type: application/sdp
    Contact: sip:150@192.168.1.59:5060
    Supported: replaces
    User-Agent: Patton SN4638 5BIS UI MxSF v3.2.8.45 00A0BA0385B1 R4.2 2008-01-17 H323 SIP BRI
    v=0
    o=MxSIP 0 2 IN IP4 192.168.1.59
    s=SIP Call
    c=IN IP4 192.168.1.59
    t=0 0
    m=audio 4866 RTP/AVP 8 0 101
    a=rtpmap:8 PCMA/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    a=sendrecv
    01:16:32 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    SIP/2.0 407 Proxy Authentication Required
    Proxy-Authenticate: Digest nonce="12850076510:7a981116656139979e30bb5aa80db170",algorithm=MD5,realm="3CXPhoneSystem"
    To: <sip:553@192.168.1.87>;tag=470ce02b
    User-Agent: 3CXPhoneSystem 5.1.4287.0
    Content-Length: 0
    01:16:32 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    ACK sip:10006@192.168.1.87 SIP/2.0
    Max-Forwards: 70
    Content-Length: 0
    To: sip:553@192.168.1.87;tag=470ce02b
    CSeq: 1713200681 ACK
    Via: SIP/2.0/UDP 192.168.1.59:5060;branch=z9hG4bK9aa87d152
    Max-Forwards: 70
    Content-Length: 218
    CSeq: 1713200682 INVITE
    Supported: timer
    Proxy-Authorization: Digest response="9314e770300bcfff767b954a574969f0",username="10006",realm="3CXPhoneSystem",nonce="12850076510:7a981116656139979e30bb5aa80db170",algorithm=MD5,uri="sip:10006@192.168.1.87"
    Supported: replaces
    v=0
    s=SIP Call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    01:16:33 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    Max-Forwards: 70
    Content-Length: 218
    Supported: timer
    Supported: replaces
    v=0
    s=SIP Call
    t=0 0
    a=fmtp:101 0-15
    a=sendrecv
    01:16:33 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    SIP/2.0 180 Ringing
    Contact: <sip:150@192.168.1.87:5060>
    To: <sip:553@192.168.1.87>;tag=0a446132
    Content-Length: 0
    SIP/2.0 180 Ringing
    Content-Length: 0
    01:16:43 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    SIP/2.0 200 OK
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Content-Length: 262
    v=0
    o=3cxPS 184733925376 307375374337 IN IP4 127.0.0.1
    s=3cxPS Audio call
    c=IN IP4 127.0.0.1
    t=0 0
    m=audio 7012 RTP/AVP 8 0 101
    c=IN IP4 127.0.0.1
    a=fmtp:101 0-16
    a=rtpmap:8 pcma/8000
    a=rtpmap:0 pcmu/8000
    a=sendrecv
    01:16:43 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    ACK sip:150@192.168.1.87:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.59:5060;branch=z9hG4bKe71802fad
    Max-Forwards: 70
    Content-Length: 0
    To: sip:553@192.168.1.87;tag=0a446132
    CSeq: 1713200682 ACK
    01:16:47 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    BYE sip:150@192.168.1.59:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.87:5060;branch=z9hG4bK-d87543-7f3c715f1a2b5116-1--d87543-;rport
    Max-Forwards: 70
    To: <sip:150@192.168.1.87>;tag=8e83cb9af8b8713
    CSeq: 2 BYE
    Content-Length: 0
    01:16:48 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    SIP/2.0 200 OK
    CSeq: 2 BYE
    Content-Length: 0
    Supported: replaces
    I do not understand why 3cx tells patton the RTP is 127.0.0.1
    The same for a outgoing call everything is working:
    192.168.1.59#01:20:45 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    INVITE sip:150@192.168.1.59:5062 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.87:5060;branch=z9hG4bK-d87543-0c619122bf55550c-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:553@192.168.1.87:5060>
    To: <sip:150@192.168.1.59:5062>
    From: "553"<sip:553@192.168.1.87:5060>;tag=b661877d
    Call-ID: ZGE5NDVmMDUxMGI3NTNkNjc3Yjc1ODY2NGFhZTEwZmI.
    CSeq: 1 INVITE
    Content-Length: 402
    v=0
    o=3cxPS 288870105088 58216939521 IN IP4 192.168.1.87
    s=3cxPS Audio call
    c=IN IP4 192.168.1.87
    t=0 0
    m=audio 7018 RTP/AVP 0 8 3 13 18 110 99 101
    a=fmtp:18 annexb=no
    a=rtpmap:3 GSM/8000
    a=rtpmap:13 CN/8000
    a=rtpmap:18 G729/8000
    a=rtpmap:110 iLBC/8000
    a=rtpmap:99 SPEEX/8000
    a=sendrecv
    01:20:45 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    SIP/2.0 100 Trying
    CSeq: 1 INVITE
    From: "553" <sip:553@192.168.1.87:5060>;tag=b661877d
    To: <sip:150@192.168.1.59:5062>;tag=e249033642eec68
    Content-Length: 0
    SIP/2.0 183 Session Progress
    CSeq: 1 INVITE
    Content-Length: 0
    Contact: sip:150@192.168.1.59:5062
    SIP/2.0 180 Ringing
    CSeq: 1 INVITE
    Content-Length: 0
    01:20:47 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Content-Length: 201
    Supported: replaces
    v=0
    o=MxSIP 0 3 IN IP4 192.168.1.59
    s=SIP Call
    t=0 0
    m=audio 4868 RTP/AVP 0 8 101
    a=sendrecv
    01:20:47 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    ACK sip:150@192.168.1.59:5062 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.87:5060;branch=z9hG4bK-d87543-c062c238314f9c13-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 1 ACK
    Content-Length: 0
    01:20:49 SIP_TR> [GW] > Stack: to 192.168.1.87:5060
    BYE sip:553@192.168.1.87:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.59:5062;branch=z9hG4bKba7dcece5
    Max-Forwards: 70
    Content-Length: 0
    To: "553" <sip:553@192.168.1.87:5060>;tag=b661877d
    From: <sip:150@192.168.1.59:5062>;tag=e249033642eec68
    CSeq: 1008093515 BYE
    Supported: timer
    Supported: replaces
    01:20:49 SIP_TR> [GW] < Stack: from 192.168.1.87:5060
    SIP/2.0 200 OK
    To: "553"<sip:553@192.168.1.87:5060>;tag=b661877d
    Content-Length: 0
    Anyone a iddee?
    regards
    Alex
