Still NOT resolved the trunk between 3CX and Cisco CME
Discussion in '3CX Phone System - General' started by Manouchehr, Jan 26, 2017.
  1. Manouchehr
    Jan 17, 2017
    28
    Hello all,
    Can anyone provide a working configuration, on how to establish a sip trunk between a 3CX and Cisco call manager?
    #1 Manouchehr, Jan 26, 2017
    sergiodo20 likes this.
  2. dan_tx
    Nov 3, 2016
    99
    27
    Don't have a Cisco Call manager, but setup a sip trunk between 3CX and an Altigen PBX. Basically just like setting up another SIP trunk to a VOIP provider just point them to each other. We couldn't "bridge" them but created inbound and outbound rules to make it pretty good for end users while we work on testing and moving to 3cx. You might have to do that. Can you add 3cx as a VOIP/SIP provider to the Cisco? For the Cisco users route 3CX extensions numbers over that sip trunk to 3cx, create DID rules pointing to the extensions?
  3. datamerge
    datamerge New Member
    Nov 19, 2014
    176
    22
    Bridging can work, but you will probably not get the correct caller ID on calls to/from the 3CX. Creating a SIPn trunk and then adding all the extensions in as DIDs, as tedious at it is, seems to be the best way.
  4. leejor
    10,754
    286
