Stopping extensions ringing other extensions
Discussion in '3CX Phone System - General' started by ryan, Sep 16, 2007.
  1. ryan
    Aug 27, 2007
    35
    Hi all.
    Is there a way that I can stop certain extensions ringing any other extension?
    I know I can click ignore on the softphone, but wondered if its possible within the software?
    Cheers
    Ry
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Within 3CX I am not aware of any denial rules, though there are some Wizards here that are very good at inventing some unique solutions. A simple one I can think of would be dependent on the devices used as extensions. If they used dial plans (PAP2, Eyebeam, etc.) you could write the exclusions into the plans.
