Stops Iphone Sounds
Discussion in 'iOS' started by mhnichols, Sep 21, 2010.
  1. mhnichols
    May 22, 2009
    11
    I have installed and tested on my 3GS running OS 4.1, not jailbroken
    Using over Wifi both locally at my office and through VPN at home works well,
    But when the app is loaded, no other sounds work on the handset, no text message alerts, no email alerts etc, no keypress sounds etc, which is a real problem, as when the phone is in standby, you do not know when you receive anything.
    Otherwise the app looks good.
    Would also be better is the exit option actually closed the app completely
    Look forward to trying the next version.
    Mark
  2. StefanW
    Jun 2, 2009
    1,216
    88
    its at the moment knowing that all backgrounds tasks are hold to be sure that no other task is crashing the app by popping frwd. first in the list will be that the ipod will still play while app is running.
  3. mckay9012
    Sep 24, 2010
    Don't know if you got this solved or not but I can confirm it happens. I'm using HTC Wildfire and the exact same thing happens on my phone.
