Strange behaviour of VoIP Unlimited trunk
Discussion in '3CX Phone System - General' started by billives, Jan 11, 2008.
  1. billives
    Nov 4, 2007
    5
    I wonder if someone can help, as I am seeing rather odd behaviour.
    I have a VoIP Unlimited trunk, 01223 654130. Associated with it are 10 DID numbers.
    I set this up so the trunk registers, and add the DID as per instructions. Some days everything works as expected, other times I get NU tones whenever calling one of the DIDs, or "The number is not recognised" messages other times (from the same telephone line, calling the same DID!).
    Right now the main trunk does not seem to be registered, along with all the DIDs excepting 01223 254131, which works as programmed.
    I am very puzzled.
    A print out from the system logs
    20:42:53.687 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.100:5060
    20:42:51.078 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.100:5100;user=phone
    20:42:50.421 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    20:41:17.625 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:01223654130@212.159.88.153:41028;rinstance=841fce72f731a200 SIP/2.0
    Via: SIP/2.0/UDP 91.151.2.130;branch=z9hG4bK05e9.ae17a5a.2
    Via: SIP/2.0/UDP 91.151.2.162:5060;rport=5060;branch=z9hG4bKc2a05b7c7da1992c935d9daee25a6eca
    Max-Forwards: 10
    Record-Route: [sip:91.151.2.130;lr=on;ftag=3409072882-347141]
    Contact: [sip:07785336113@91.151.2.162:5060]
    To: [sip:01223654130@91.151.2.162:5060]
    From: [sip:07785336113@91.151.2.162];tag=3409072882-347141
    Call-ID: 1220597-3409072882-347081@msw8.mydomain.com
    CSeq: 1 INVITE
    Session-Expires: 3600;Refresher=uac
    Supported: timer
    Allow-Events: telephone-event
    Content-Length: 0
    Remote-Party-Id: [sip:07785336113@91.151.2.162];party=calling;screen=yes;privacy=off
    P-hint: usrloc
    20:41:17.609 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 01223654130@212.159.88.153:41028 tid=05e9.ae17a5a.2 cseq=INVITE contact=07785336113@91.151.2.162:5060 / 1 from(wire)
    20:41:17.609 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 91.151.2.130;branch=z9hG4bK05e9.ae17a5a.1
    Max-Forwards: 10
    CSeq: 1 INVITE
    Supported: timer
    Content-Length: 0
    P-hint: usrloc
    20:41:17.609 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 01223654130@212.159.88.153:41028 tid=05e9.ae17a5a.1 cseq=INVITE contact=07785336113@91.151.2.162:5060 / 1 from(wire)
    20:41:17.593 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:01223654130@212.159.88.153:41028;rinstance=fa7150273f3eeb4d SIP/2.0
    Via: SIP/2.0/UDP 91.151.2.130;branch=z9hG4bK05e9.ae17a5a.0
    Max-Forwards: 10
    CSeq: 1 INVITE
    Supported: timer
    Content-Length: 0
    P-hint: usrloc
    20:41:17.593 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 01223654130@212.159.88.153:41028 tid=05e9.ae17a5a.0 cseq=INVITE contact=07785336113@91.151.2.162:5060 / 1 from(wire)
    20:41:03.671 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10000@voipunlimited
    20:41:03.359 ClientRegs::Register [CM504003]: Sent registration request for 10000@voipunlimited
    20:31:14.718 ExtnCfg::updateContact [CM504001]: Ext.1003: new contact is registered. Contact(s): [sip:1003@192.168.1.25/1003]
    20:28:58.375 ExtnCfg::updateContact [CM504001]: Ext.1002: new contact is registered. Contact(s): [sip:1002@192.168.1.26/1002]
    20:26:49.156 ExtnCfg::updateContact [CM504001]: Ext.1005: new contact is registered. Contact(s): [sip:1005@192.168.1.17:10626;rinstance=5b3d17bc7c3e0628/1005]
    20:25:05.156 ExtnCfg::updateContact [CM504001]: Ext.1001: new contact is registered. Contact(s): [sip:1001@192.168.1.16/1001]
    20:23:01.828 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10001@sipgate
    20:23:01.781 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10000@voipunlimited
    20:23:01.656 ClientRegs::Register [CM504003]: Sent registration request for 10001@sipgate
    20:23:01.609 ClientRegs::Register [CM504003]: Sent registration request for 10000@voipunlimited
    20:22:54.515 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10001@sipgate
    20:22:54.468 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10000@voipunlimited
    20:22:54.218 ClientRegs::Register [CM504003]: Sent registration request for 10001@sipgate
    20:22:54.187 ClientRegs::Register [CM504003]: Sent registration request for 10000@voipunlimited
    20:22:53.546 StunClient::process [CM506002]: Resolved SIP external IP:port (212.159.88.153:41028) on Transport 192.168.1.100:5060
    Help please. I really want to roll this out to clients, but cannot while this is happening, and I am unable to explain.
