Strange call flow request
Discussion in '3CX Phone System - General' started by hood, Jun 19, 2017.
  1. hood
    Jun 2, 2015
    36
    Hi All,
    I've had a client throw a curly one at me, as they are used to a key system rather than a PBX.
    They have asked for a way to retrieve a call, that has been transferred to Person B. Person B has answered the call and put it on hold and left the call on hold and walked away.
    I'm guessing with their old key system they could just pick up "Line 1" again to grab the call.
    Seems a little unusual and I'm not sure of the best way to tackle it.
    Thanks in advance
    11,095
    327
    There have been a number of posts, in the past, on setting-up sets in one department to behave as an old key system, using BLF keys. You will have to do some searching (sometimes Google is the best method). How well this functions will also depend on the make/model sets you are using.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I think youre wanting to use shared parking ... it works great in 3cx, better than traditional call park.
    YiannisH_3CX likes this.
  4. saqqara16
    Jan 13, 2016
    46
    7
    As above shared parking, the way to go
  5. hood
    Jun 2, 2015
    36
    Thanks guys.
    I'll look int the shared park, and look at re-educating the user.
    For the record the handsets are Yealink T42G's
