strange errors
Discussion in '3CX Phone System - General' started by dlrmartin, Sep 13, 2007.
  1. dlrmartin
    Jul 26, 2007
    15
    hello,
    please could you give me any idea why this errors?
    14:05:27.437|MSEndPoint.cpp(780)|Critical0||??:[MS005001] Call(62) Ext.120: payload #126 doesn't correspond initial SDP datalen=4
    14:05:39.703|MSCallConf.cpp(233)|Critical0||??:[MS004000] Call(62) Ext.120: (ACTIVE): Can't send RTP stream to 0.0.0.0:10946 destination unreachable
    14:05:49.984|MSEndPoint.cpp(780)|Critical0||??:[MS005001] Call(62) Ext.120: payload #126 doesn't correspond initial SDP datalen=4
    14:06:00.546|MSEndPoint.cpp(780)|Critical0||??:[MS005001] Call(62) Ext.120: payload #126 doesn't correspond initial SDP datalen=4
    14:06:10.000|MSCallConf.cpp(238)|Error1||??:[MS104000] Call(62) Ext.120: (ACTIVE) RTP stream to 192.168.7.107:10946 restored.
    14:06:10.015|MSEndPoint.cpp(780)|Critical0||??:[MS005001] Call(62) Ext.120: payload #126 doesn't correspond initial SDP datalen=4
    I'm searching to fix to issues:
    1. when pick up a tranfered call, I have audio but like my mute were on.
    pressing hold twice audio is ok.
    2.still I have some delay on one way from me to PSTN listener, in the other way no delay.
    I have:
    3cx last version
    SPA400 gateway
    xlite soft phones.
    thanks,
    Martin
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    About "#126":
    You need to ask X-lite support about why it happens. :)
    About transfer:
    Problem is not related to "#126". It will be good of you provide some more information about call.
    About delay:
    Additional information is necessary as well.
    Anyway, please describe your use case. It is very difficult to investigate problems like "something going wrong". :)
  3. dlrmartin
    Jul 26, 2007
    15
    thanks for the answer:
    my environment:
    3cx: last version
    pstn gateway: Linksys SPA400
    SO: Wndows server 2003
    Phones: Xlite softPhone
    My most critical problem is delay.
    How delay is?
    Call is incoming from PSTN -> I pick up the phone.
    OK, no problem... for first 30 seconds.
    After this time, starts to appears a small voice delay from me to PSTN Caller. At 60 seconds talking delay increase, at 90 seconds I have a big delay!
    in the other voice way, the caller voice is heared without delay at 3cx phone ever.
    Sample:
    Me (at 3cx) Caller (PSTN line caller)
    Call Time: 0 seconds
    Hello>>>>>>>>>>0 sec>>>>>>>Hello
    Hello<<<<<<<<<<0 sec<<<<<<<Hello
    Call Time: 30 seconds
    Hello>>>>>>>>>>1 sec>>>>>>>Hello
    Call Time: 60 seconds
    Hello>>>>>>>>>>2 sec>>>>>>>Hello
    Call Time: 90 seconds
    Hello>>>>>>>>>>3 sec>>>>>>>Hello
    Call Time: 120 seconds
    Hello>>>>>>>>>>4 sec>>>>>>>Hello
    and then.....
    Trick to fix:
    when delay start to make impossible to talk, I press hold twice and delay is reseted!!! starting again.
    I made several test checking and unchecking varios parameters at 3cx:
    bind to media, support reinvite, supports replace header, but I can't supress the delay.
    Do you need more info, logs, anything to help me?
    thanks!
    Martin
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    About Xlite i have no idea. About the delay on the SPA400, if im not mistaken SPA3102 is pretty much the same but is the newer device of the kind...
    Try to change the line impedance values to adjust the "Echo" worked here :D
    Cheers
  5. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Just to let you know that the spa400 was build by linksys to only work with the SPA9000. You might get it to work with 3cx but no promises about it behaving 100% correctly.
  6. dlrmartin
    Jul 26, 2007
    15
    thanks for the answer.
    no way changing impedance, I have delay...
    I know that spa400 is designed to work with 9000, but all works ok, only this detail about delay..!
    As I stated, when Press hold twice, delay is reseted and I have following logs:
    20:08:51.203 MediaServerReporting::RTPSender [MS104000] Call(46) Ext.123: (ACTIVE) RTP stream to 192.168.7.1:29498 restored.
    20:08:48.390 MediaServerReporting::RTPSender [MS004000] Call(46) Ext.123: (ACTIVE): Can't send RTP stream to 0.0.0.0:29498 destination unreachable
    what means?
    I'm sure, that some troubleshooting going to supress delay ;)
    thanks
  7. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Just after a quick glance it appears to be dropping the IP, 0.0.0.0 is not valid obviously. Depressing hold restores the IP. Why? I haven't a clue :oops: . Just observing right now. Sorry.
  8. dlrmartin
    Jul 26, 2007
    15
    I'm lost too.
    may be 3cx staff can help me to find a clue.
