Strange Messages after Update to 15.5 SP2
Discussion in '3CX Phone System - General' started by narkumas, Nov 21, 2017.
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    11/21/2017 10:52:44 AM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    11/21/2017 10:52:20 AM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    11/21/2017 10:52:15 AM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
  2. StefanW
    Jun 2, 2009
    1,167
    75
    better ;-)
    something (a sip endpoint) is sending the PBX a message which does not contain the SIP Contact Header or it is inclomplete. This is mandatory. Which SIP endpoints or provider do you use? Any other then defined in our supported list?
  3. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    Well, we have 1 or 2 Cisco SPA112... The rest is supported.
    And this started happening after SP2 Upgrade...
    Our Provider is QSC
  4. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    How can I identify which SIP endpoint is causing this?
  5. StefanW
    Jun 2, 2009
    1,167
    75
    wireshark would be the simplest, QSC is not doing it for sure...
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    should I send you a pcap dump?
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Please send me a p.m. with a capture. We might also need to see the phones systems support info in verbose but lets start with the capture.
    Please update the file to a web sharing service and send me the download link in a p.m.
  8. KOG
    KOG
    Dec 20, 2017
    I have the same issue after the update.
    12/20/2017 3:27:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    12/20/2017 3:26:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    12/20/2017 3:25:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    12/20/2017 3:24:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    12/20/2017 3:23:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    12/20/2017 3:22:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
    12/20/2017 3:21:59 PM - Exception: SipMessage::Exception Missing header Contact @ SipMessage.cxx:1393
  9. Mark Tonino
    Dec 18, 2017
    Same here...
  10. DrewHammond
    Oct 14, 2016
    8
    We are seeing this as well
  11. loyer
    May 5, 2016
    42
    Was this ever resolved? I am getting this now and not sure how to fix. Thank you for any info.
  12. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Please note that this is not an issue of the PBX. As mentioned above you are seeing this because an endpoint is trying to register to the PBX using an incorrect header. If you need assistance i will be happy to take a look if you provide me with the files mentioned above in a p.m.
  13. loyer
    May 5, 2016
    42
    Hi Yiannis,
    I am using Yealink T48S phones. The phones were initially provisioned via Direct SIP / STUN and then recently switched to SBC. Another user said that the MAC address might be hardcoded for 14 days. Do you think this would cause this issue? My phones are on the latest supported firmware and were provisioned using the 3CX system (currently 15.5SP3).
    Thank you
  14. YiannisH_3CX
    May 10, 2016
    4,349
    274
    I do not think the messages you are receiving are related to that. These are probably register messages towards the PBX that are not correctly formatted.
  15. Robert Cook
    Jan 7, 2018
    Greetings,
    I too am having this issue:
    I'll PM you YiannisH my information.
    Thank you,
    Robert Cook
  16. Mischa Sz.
    Dec 5, 2017
    7
    Hi!
    Same issue here. I cannot dial numbers through the web client anymore. Using a Yealink T48S connected through an SBC (Linux). 3CX version 15.5 Professional.
    Regards
    Mischa
  17. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Do you have Snom phones as well by any chance? In order to troubleshoot your issue we will need the PBX logs in verbose logging level and a wireshark capture from the PBX at the time of the issue. Please send me a p.m. with the requested files or for details on how to collect these files.
  18. Mischa Sz.
    Dec 5, 2017
    7
    After restarting all 3CX services, the issue has gone. Best regards, Mischa
