- Joined
- Jun 2, 2007
- Messages
- 122
- Reaction score
- 0
The system used to be running reasonable smooth (every now and then they had one side audio internal) but problems seem to get worse every day.
Now customers start complaining and internal calls hardly work.
Everything registers fine and all seems to be ok.
I found two error messages in the serverlog from today, maybe they shed some light on the issue. My customer is getting really impatient now so im hoping for a quick reply.
Thanks in advance,
DaKhalli
Server log:
13:53:42.093 CallConf:nProvisional [CM103003] Call(56): Ext.110 is ringing
13:53:42.000 CallConf:nIncoming [CM103002] Call(56): Incoming call from 0624750396 (Ln:10001@Voiceworks Notom) to sip:[email protected]:5080
13:54:03.218 MediaServerReporting::RTPSender [MS004000] Call(56) Ext.110: (ACTIVE): Can't send RTP stream to 0.0.0.0:5006 destination unreachable
13:53:49.078 CallLegImpl:nConnected [CM103001] Call(56): Created audio channel for Ext.110 (10.10.1.41:5006) with Media Server (10.10.1.12:7148)
13:53:49.046 StratInOut:nConnected [CM104005] Call(56): Setup completed for call from Ln:10001@Voiceworks Notom to Ext.110
13:53:49.031 CallLegImpl:nConnected [CM103001] Call(56): Created audio channel for Ln:10001@Voiceworks Notom (213.239.164.176:17722) with Media Server (84.107.147.253:8000)
13:54:38.234 StratLink:nHangUp [CM004001] Call(56): HangUp from wrong leg has arrived. Leg will be removed from call
13:54:37.937 MediaServerReporting:TMFhandler [MS211000] Call(56) Ln:10001@Voiceworks Notom: DTMF (in-band) from 213.239.164.176:17722 detected.
13:54:31.140 CallLegImpl:nConnected [CM103001] Call(56): Created audio channel for Ext.520 (10.10.1.46:16418) with Media Server (10.10.1.12:7152)
13:54:31.140 StratTransfer::finishTransfer [CM108005] Call(56): Transfer finished, Ln:10001@Voiceworks Notom is connected to Ext.520
13:54:31.140 StratTransfer:nConnected [CM008008] Call(56): Transfer: wrong leg is connected
13:54:31.109 StratLink::Transfer [CM104002] Call(56): transfers Ln:10001@Voiceworks Notom from Ext.110 to sip:[email protected]
11:13:07.609 CallConf::Rejected [CM103005] Call(36) is rejected: Declined
11:13:07.609 StratInOut:nCancel [CM104008] Call(36): Call from Ext.630 to 0627563617 terminated; cause: 603 Declined; from IP:213.239.164.175
11:12:22.093 CallConf:nProvisional [CM103003] Call(36): Ln:10001@Voiceworks Notom is ringing
11:12:21.671 CallConf:nIncoming [CM103002] Call(36): Incoming call from 630 (Ext.630) to sip:[email protected]
Thanks in advance,
DaKhalli
Server log:
