strip Digits / rule make outbound calls
Discussion in '3CX Phone System - General' started by NetTel, Dec 22, 2007.
  1. NetTel
    Jul 12, 2007
    5
    I have just opgrade to V5
    I would like to make a rule for making outbound calls. strip digits to 0 and not standard 1. but I can not change this, I get a error
    Cannot save Outbound rule object: add range: ERROR: duplicate key violates unique constraint "dnrange2rule_pkey"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fOutboundRule.php(130): safeExec(Object(PDOStatement), 'Cannot save Out...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\dialingplan_info.php(99): fOutboundRule::save(Object(oOutboundRule))<br />
    #2 {main}
    Can you pleace help me :shock:
    ps. no problem in making the first 3 rules. but the no can´t do.
  2. NetTel
    Jul 12, 2007
    5
    fixed
    I have fixed the problem, I reloaded the backup and then the problem whas fixed.
