Strip more digits in outbound rules
Discussion in 'Ideas' started by Benedikt Machens, Apr 10, 2018.
Strip more digits in outbound rules 5 5 1votes
5/5, 1 vote
  1. Benedikt Machens
    Feb 14, 2018
    Currently you can strip up to 9 digits from and outbound call
    If you want to realize least cost routing via bridges it would be nice to strip more digits
    For example
    Bridge Prefix is 101 and 3 digits for the extension (101-xxx)
    Users may not dial the 101, because they dial via a phonebook or something else. They dial the DID from the Bridge PBX
    0049 221 1234 - xxx
    To redirect this call to the bridge and set the correct number you need to strip 11 digits
    So it would be nice to strip more digits (like 15, 20, 30?!). So you are free in your configuration and make least cost more user friendly
  2. xadves
    Apr 10, 2018
    Other PBX's let you write regex to route the calls and format them however you'd like. I'd like to see a more advanced option like this in the routing area. I actually just ran into this too, where I wanted to have greater control over the numbers dialed, the route, and what number was sent to the route.
    HH60 likes this.
