Stuck call on Listen in.
Discussion in 'Windows' started by pedroben, Mar 8, 2017.
  1. pedroben
    Aug 2, 2016
    10
    I have a user who used this function yesterday however, that leg is still hung on the 3CX client 22hrs later.
    I cant drop the leg as an admin.
    Also, looking on active calls on the portal, it says 1 but cant see any calls once i vew. Think somebody else reported this issue.
    Any ideas?
