STUN check failure
Discussion in 'Windows' started by genmail, Nov 9, 2010.
  1. genmail
    Nov 9, 2010
    As of today, I have been unable to get 3CX phone to connect to gizmo network to receive calls made to Gizmo telno, even though I previously had no problem doing so, and have not (knowingly) changed any settings in hardware or software. I can still receive calls to Gizmo telno using Gizmo's own client, so gizmo appears to be working. Tried reinstalling 3CX v5 to repl v4. Also tried changing STUN settings to those recommended by 3cx system forum users; that led to 'authentication failure' vs simply 5 failed attempts to connect each time. Gizmo claims its stun port is 3478 but no evident way to incl that in 3cx config; tried making stun setting in 3cx first stun01.sipphone.com and then stun01.sipphone.com:3478; both failed. If this isn't a STUN problem, what is it? Please advise.
    Following is debug:
    DX:MP3 Writer initialized
    DX:MP3 Encoder initialized
    DX:FFDShow not present
    Integration with 3CX Call Assistant is OFF
    Translation file OK
    Attempting to connect 198.65.166.131
    Phone got as local port 3047
    Plantronics not connected
    Jabra not connected
    Yealink not connected
    RTP engine OK
    SIP engine OK
    Sound mic device OK []
    Sound ring device OK []
    Sound speaker device OK []
    Sending STUN request
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Unable to contact STUN
    Translation file OK
    Translation file OK
    Phone requested as local port 3478
    Phone requested local port OK
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Translation file OK
    Phone got as local port 3075
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    Translation file OK
    Translation file OK
    STUN check failed
    STUN check failed
    Translation file OK
    Phone got as local port 3076
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Translation file OK
    Phone got as local port 3079
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Phone got as local port 3125
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Not connected: Authentication failed
    Phone has been disconnected - error: 401
    Phone is no longer connected
    Phone connection failed, PBX not responding
    Translation file OK
    Phone got as local port 3129
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Translation file OK
    Phone got as local port 3135
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Translation file OK
    Phone got as local port 3140
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Phone got as local port 3144
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, just checked our 3CX system and we are now seeing stun timeout, will let 3CX support know and hope they fix it.
  3. genmail
    Nov 9, 2010
    Thanks. After several more failed attempts this am, was able to get 3cxphone to connect, but am concerned about recurrence of prob.
