Stun problem
Discussion in '3CX Phone System - General' started by jamie2000ukuk, May 20, 2011.
  1. jamie2000ukuk
    Mar 1, 2011
    12
    Hi have unbloacked all the ports I need to but cant get a phone from our office to connect external. I can connect from the external phone into the system but no the other way around I have tried 3cx stun but it seems to make thing worse humm.... I have 9000-9049 open and 5060
    Here my logs any help
    22:34:46.275 [CM503025]: Call(8): Calling Ext:Ext.210@[Dev:sip:210@82.31.218.122:5062]
    22:34:46.272 [MS101003] C:8.2: Possible firewall problem. Address mapping failed on STUN server 77.72.169.164:3478 for local address "81.139.168.214:9016"
    22:34:46.272 [MS201000] Use STUN server 'stun.voipbuster.com:3478'
    22:34:46.270 [MS101005] STUN request failed for ports 9016,9017 on STUN server 'stun3.3cx.com:3478'
    22:34:46.220 [MS201000] Use STUN server 'stun3.3cx.com:3478'
    22:34:46.198 [MS101005] STUN request failed for ports 9016,9017 on STUN server 'stun2.3cx.com:3478'
    22:34:46.061 [MS201000] Use STUN server 'stun2.3cx.com:3478'
    22:34:46.061 [MS101005] STUN request failed for ports 9016,9017 on STUN server 'stun.voipbuster.com:3478'
    22:34:45.948 [CM503004]: Call(8): Route 1: Ext:Ext.210@[Dev:sip:210@82.31.218.122:5062]
    22:34:45.945 [CM503010]: Making route(s) to <sip:210@192.168.0.11:5060>
    22:34:45.943 [CM505003]: Provider:[VOIP] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:01163680985@81.139.168.214:5060]
    22:34:45.937 [CM503001]: Call(8): Incoming call from 07903863625@(Ln.10000@VOIP) to <sip:210@192.168.0.11:5060>
    22:34:45.920 [MS101003] C:8.1: Possible firewall problem. Address mapping failed on STUN server 77.72.169.164:3478 for local address "81.139.168.214:9014"
    22:34:45.920 [MS201000] Use STUN server 'stun.voipbuster.com:3478'
    22:34:45.918 [MS101005] STUN request failed for ports 9014,9015 on STUN server 'stun3.3cx.com:3478'
    22:34:45.868 [MS201000] Use STUN server 'stun3.3cx.com:3478'
    22:34:45.856 [MS101005] STUN request failed for ports 9014,9015 on STUN server 'stun2.3cx.com:3478'
    22:34:45.718 [MS201000] Use STUN server 'stun2.3cx.com:3478'
    22:34:45.705 [MS101005] STUN request failed for ports 9014,9015 on STUN server 'stun.voipbuster.com:3478'
    22:34:45.622 [CM503012]: Inbound out-of-office hours rule (01455330996) for 10000 forwards to DN:210
    Any help would be good :))
  2. willow
    willow Member
    Mar 1, 2011
    471
    it appears that you may not have the ports open correctly. Does your router have a log option for packets that it is dropping?
  3. leejor
    10,752
    285
    Try putting the PC running 3CX on DMZ, see if it works, then go back and "revisit" the port forwarding (and other) options.
    I haven't seen other ports mentioned before in the server, log when doing a STUN test, it all happens over one port. The 3CX firewall test does check all ports.
