STUN Problems - urgent!
Discussion in '3CX Phone System - General' started by Zebramanager, Nov 9, 2010.
  1. Zebramanager
    Nov 9, 2010
    my 3cx ver. 5 is not connecting anymore to the STUN Server.
    When I check the debug it tells me with red: STUN check failed. Unable to contact STUN.
    Please help! It is urgent.
    Regards
    Zebra
  2. rizzz
    Jun 25, 2009
    29
    hi,
    I had this problem too.
    Put stun.xten.com (for e.g.) instead of stun.3cx.com to solve this problem.
  3. DXS_Matt
    Feb 12, 2009
    41
    another that we have found to be rock solid is stun.counterpath.com
  4. Zebramanager
    Nov 9, 2010
    Thanks for this quick answer, but do you think the problem will be solved soon?
    I would have to contact about 100 partners to change the settings and it is not that easy. I will do this only if the problem won't be solved in max. 24h.
    Thanks again.
  5. genmail
    Nov 9, 2010
    I experienced same problem as of today, though no settings changed manually in hardware or software. Previously had no problem connecting to network (gizmo) using 3cx softphone. Still no problem rec calls using Gizmo's own client, so gizmo appears to be working. Tried reinstalling 3CX telw v5. Also tried changing STUN settings to those recommended by other forum users; that led to 'authentication failure' vs simply 5 failed attempts to connect each time. Gizmo claims its stun port is 3478 but no evident way to incl that in 3cx config; tried making stun setting in 3cx first stun01.sipphone.com and then stun01.sipphone.com:3478; both failed. Please advise.
    Fol is debug:
    DX:MP3 Writer initialized
    DX:MP3 Encoder initialized
    DX:FFDShow not present
    Integration with 3CX Call Assistant is OFF
    Translation file OK
    Attempting to connect 198.65.166.131
    Phone got as local port 3047
    Plantronics not connected
    Jabra not connected
    Yealink not connected
    RTP engine OK
    SIP engine OK
    Sound mic device OK []
    Sound ring device OK []
    Sound speaker device OK []
    Sending STUN request
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Translation file OK
    Phone requested as local port 3478
    Phone requested local port OK
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Translation file OK
    Phone got as local port 3075
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    Translation file OK
    Translation file OK
    STUN check failed
    STUN check failed
    Translation file OK
    Phone got as local port 3076
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Translation file OK
    Phone got as local port 3079
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Phone got as local port 3125
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Not connected: Authentication failed
    Phone has been disconnected - error: 401
    Phone is no longer connected
    Phone connection failed, PBX not responding
    Translation file OK
    Phone got as local port 3129
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Translation file OK
    Phone got as local port 3135
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Translation file OK
    Phone got as local port 3140
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    Translation file OK
    Phone got as local port 3144
    Jabra not connected
    RTP engine OK
    SIP engine OK
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
    STUN check failed
