STUN requests timing out
Discussion in '3CX Phone System - General' started by esmadja, Jan 14, 2008.
  1. esmadja
    Jan 12, 2008
    8
    All my STUN requests seem to be timing out. I am trying to setup a VoIP line using callcentric.
    I have the following configured.
    VoIP Provider = callcentric
    Registrar/Proxy Hostname or IP: callcentric.com
    Outbound Proxy Hostname or IP: callcentric.com
    Registrar/Proxy Port: 5060
    Outbound Proxy Port (default is 5060): 5060
    Registration settings
    Time between registration attempts (in seconds): 3600
    Require (optionally: authorized) registration for: Both in-out calls
    Which IP to use in 'Contact' field for registration: Internal
    Codec Priorities
    Assigned codecs: G.711U-law
    G.711A-law
    GSM-FR
    External Number: 1777MYCCID
    Authentication ID: 1777MYCCID
    Authentication Password: <SUPERSECRET>
    Where 1777MYCCID is my Callcentric number and <SUPERSECRET> is the same password I used when creating my Callcentric account.
    Outbound Rule
    Rule Name: Rule for "callcentric"
    Calls to Numbers starting with:
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    have you opened the port for the stun server?
    what does the firewall test give out ?
    please poste some of youre log.
    Andy
  3. esmadja
    Jan 12, 2008
    8
    Yes the ports were opened, however it seems that after rebooting my machine the problem is resolved.
