Stun resolution failure
Discussion in '3CX Phone System - General' started by KenC, Sep 16, 2012.
  1. KenC
    Mar 29, 2012
    85
    How to troubleshoot?
    Error response received from trunk 12294
    11,116
    329
    Not a lot to go on...
    It could be a STUN server that is down. DNS problem, or internet or network issue.
    You need to provide more information.
  3. KenC
    Mar 29, 2012
    85
    system seems to be working fine. what information about the error messages should I post?
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    When you try to dial a phone number that is busy or the phone isn’t picked up, you can get error code 12294.
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    KenC -
    Well, let's see -
    Version of 3CX to include Service Pack level would be a start. The pperating system in use and whether 32 or 64 bits would also help. You titled the thread as STUN Resolution Failure and the lastest SP reportedly fixed a bug with STUN (on 64 bit systems, but perhaps in not in your case as it was reported as a fix involving STUN and one-way audio). Given the title of the thread and the error code with no explanation of where observed, any ill -effects, any logs, or if any conditions existed at the time of the observation....we are all guessing.
    How often does the error occur, is this new or has it been going on for a while?
    Do you have a fixed public IP at the location where 3CX is located? Do you need STUN?
    It may also simply be that the STUN server was down at the time. I know that 3CX has had some issues as of late keeping the servers alive, but they may have been able to resolve by now. If you don't need STUN, then turn it off and use your fixed IP instead.
