stun server problem - calls failing
Discussion in '3CX Phone System - General' started by giorgiobusoni, Sep 22, 2011.
  1. giorgiobusoni
    Apr 6, 2011
    32
    Here is the log:
    what should I do? add different stun server? enable keep alive? using 3cx v10 sp3
    10,375
    231
    Do you even need STUN on 3CX, maybe not. Do you use a VoIP provider or just a gateway? Do you have remote extensions?
    Run the 3CX firewall checker, see what results you get. Try to correct for any errors that show up. Might be a port forwarding issue, or router incompatibility.
    What is the actual problem that you think involves STUN? It looks like an extension is terminating the call.
  3. giorgiobusoni
    Apr 6, 2011
    32
    20:09:03.560|.\SLServer.cpp(789)|Error1|MediaServer|MediaServerReporting::STUN:[MS101005] STUN request failed for ports 9000,9001 on STUN server 'stun.voip.vivavox.it:3478'<br>
    20:09:03.561|.\SLServer.cpp(789)|Error1|MediaServer|MediaServerReporting::STUN:[MS201000] Use STUN server 'stun.3cx.com:3478'<br>
    20:09:03.561|.\SLServer.cpp(789)|Error1|MediaServer|MediaServerReporting::STUN:[MS101003] C:60.1: Possible firewall problem. Address mapping failed on STUN server 96.9.132.83:3478 for local address ":9000"<br>
    I use voip provider
    Running the 3cx firewall checker it tells me that works but with translation...but I don't know way, i have configured in the windows 2008 routing and remote access to map statically those ports...
  4. leejor
    10,375
    231
    What make/model router are you using?
