STUN Server Problem
Discussion in '3CX Phone System - General' started by nahidul, Sep 27, 2009.
  1. nahidul
    Jul 9, 2007
    28
    Greetings.
    My 3CX phone system was working fine for over a year until this morning when I noticed that all the IP Phones were trying to connect to the STUN Server when I was dialing. At this time, most of the calls are not connecting and if they connect - I am not geting any voice/audio. Most of my IP Phones are external phones, located outside my home network. I checked and tested the firewall and it failed (this is the first time it failed). Please note I did not make any changes to my router nor to the 3CX system. I am getting the following error:
    Result: Firewall check failed! Hide details <<<
    # Port Status Description Parameters
    1 9000 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    2 9001 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    3 9002 Error (0) The specified port is in use by another application. error = Port is in useusedByApp = '3CX PhoneSystem Media Server' service
    4 9003 Error (0) The specified port is in use by another application. error = Port is in useusedByApp = '3CX PhoneSystem Media Server' service
    5 9004 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    6 9005 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    7 9006 Error (0) The specified port is in use by another application. error = Port is in useusedByApp = '3CX PhoneSystem Media Server' service
    8 9007 Error (0) The specified port is in use by another application. error = Port is in useusedByApp = '3CX PhoneSystem Media Server' service
    9 9008 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    10 9009 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    11 9010 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    12 9011 Error (15) STUN server did not returned a response. error = No response from STUN (timeout)stunAddr = 75.101.138.128:3478
    13 9012 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    14 9013 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    15 9014 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    16 9015 Error (15) STUN server did not returned a response. error = Socket reading error. Error 10054stunAddr = 75.101.138.128:3478
    I even directly connected the 3CX computer to internet and still the same error. I tried using different STUN servers: stunserver.org, stun.fwd.org, stun.voipbuster.com - without any success.
    Please help.
    With Thanks
    Nahid Hossain
    1-877-88-NAHID(6-2443) Toll Free
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I assume you attempted to reboot the machine to see if that fixed it?
    I would verify connectivity from the 3CX box, if that was ok then I would do a backup and restore.
  3. nahidul
    Jul 9, 2007
    28
    Greetings and Thank You for your reply.
    I restarted the computer couple times without any success. Quick question for you - should I reinstall 3CX and than do the restore? Or just backup and restore?
    Quick note - I am using v6.
    With Thanks
    Nahid Hossain
  4. ngnecco
    May 14, 2007
    Guys :
    FYI : I ran into the exact same problem and timing. Try stun.justvoip.com It worked just nice for me.
    Nelson
    ps. stun.3cx.com just points at stun.counterpath.com
  5. nahidul
    Jul 9, 2007
    28
    Greetings and Thank You.
    I tried stun.justvoip.com and tested the firewall. It passed once and 2nd time it failed. I tested again and it passed, but seconds later it failed. Any advice? Thank you in advance for the help.
    With Thanks
    Nahid Hossain
  6. girish
    May 13, 2009
    14
    Dear all
    i am also having same problem. couldn't figure out. firewall test fails and gives error (15) my 3cx was running smoothly from long time today first time i saw this problem
    Thanks and Rgds
    girish
  7. nahidul
    Jul 9, 2007
    28
    Hello Girish.
    Which version are you using? I am using v6. Could it be that I might have to upgrade? Or could it be the 3CX STUN server? I backed up and restored the system and still same problem.
    WIth Thanks
    Nahid Hossain.
  8. pc17
    Jul 31, 2009
    5
    Maybe I'm wrong here, but as I can see from your log the system is having an error with winsock, and if you tried another stun server, I should suggest that you reset your winsock.
    Windows Vista / 2008
    1. Run the following command (in cmd box preferably): netsh winsock reset
    2. Reboot the machine
    Windows XP:
    1. Remove the following register keys:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock2
    2. Reboot the machine (you'll get some errors from firewalls etc, it's normal):
    3. Reinstall TCP/IP: Start => configuration screen => network connections => Right click your LAN device, choose properties.
    Click install, click protocol, click "Have Disk", typ the following directory: c:\windows\inf and choose Internet Protocol (TCP/IP).
    4. Reboot the machine again (all errors (if you got some before) are now gone)
    That's it.
    I had some 10054 errors fixed using this.
    Let me know if it worked!
  9. girish
    May 13, 2009
    14
    hi
    i also using version 6. from today phones connected outside office started getting problems and when i checked i got the same error which is mentioned above( firewall test result.).
    Thanks and rgds
    girish
  10. tpinnovations
    Jul 30, 2009
    296
    I would upgrade to at least 7.1, 6.X is now obsolete.
  11. girish
    May 13, 2009
    14
    Dear All
    Any one got the solution for this problem? i am still having this problem. now i am going to install 7.1 and test with different internet connection and firewall. will let u know the result in few hours. any way i feel it is not going to solve the problem. all of us din't had problem and suddenly it started for all of us together that means it is nothing to do with local setting. it may be a global problem with stun server?
    Thanks and Rgds
    girish
  12. girish
    May 13, 2009
    14
    i changed stun server to stun.justvoip.com started working fine. i think stun.3cx.com is having some problem
    Thanks and rgds
    girish
  13. vinzer
    Sep 9, 2009
    21
    same solution here - changed to stun.justvoip.com since 3cx one does not work properly however respond ping OK
  14. girish
    May 13, 2009
    14
    Dear all
    It seems that stun.3cx.com is having some problem stun2.3cx.com also working fine. firewall check error comes only with stun.3cx.com stun2.3cx.com is working fine. my problem is some of my phones are far away and there stun.3cx.com is configured that phones are not working. if some one know when this stun.3cx.com will come up or it will not work no more?
    i installed 7.1 also there also same problem stun.3cx.com is not working and stun2.3cx.com is passing firewall check
    Thanks and rgds
    girish
  15. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Hello All
    Here is the list of stun servers we now use. We mapped our domain
    name to there ip address so if one goes down the system will switch
    to the other. Each stun server must have two ip's so in our case our
    two stun servers have a total of four ips.
    Hope this helps you out? :mrgreen:
    stun1.mwvs.net - west coast seattle - 64.69.76.23/64.69.76.24
    stun2.mwvs.net - east coast nyc - 69.90.168.13/69.90.168.14
    stun3.mwvs.net - west portland - 70.98.39.60/70.98.39.225
    stun4.mwvs.net - germany - 217.10.79.2/217.10.79.3
    "just added they have four ip's for one server" :shock:
    stun5.mwvs.net - DE - 77.72.169.160-162-164-166
    For now we have not had any problems with our setup & things have been
    up/running for two years. We also check from time to time to see if there
    are other stun servers out there & we just add them to the mix. Also thanks
    for the new stun server, I did not know about that one at all :p stun.justvoip.com
    ecwilson
