- Joined
- Feb 18, 2008
- Messages
- 8
- Reaction score
- 0
Today my 3CX box locked up some I came into the office to try and figure out why. I noticed the drive was completely full with WIndows reporting literally '0 bytes' free. I tracked the issue down the the 3CX logs, and then started looking at the logs to see what was in them that was so large. I get this error:
[CM506004]: STUN request to STUN server 64.69.76.23 has timed out; used Transport: 10.82.10.15:5060
EVERY 3 seconds!!!
Apparently this just started happening recently and I have no idea why (unfortunately I deleted all of the logs in haste to free up drive space so I cant exactly pinpoint when this started happening). I was able to get the machine up and running again by specifying my public IP in the contact field for each VOIP Provider so that the lines would register. Then I went into the General Settings and took out the stun.3cx.com and stun2.3cx.com, restarted the services and the error in the log went away. Everything seems to be working again... but I'd really like to know "why".
I am behind a firewall, but I have a 1to1 NAT for this box. It's a Windows XP Pro machine with SP2. I'm using 3CX 5.0.3790.0
Something else I noticed... I can no longer go to the Versions/Upgrade link.. it says the server cannot be found? (DNS resolution works for internet browsing and everything else)
Anyone have any ideas? It worked great for a couple of months...
I saw a post about making a local STUN server... what are the pros and cons of doing that? Why do I need it if it seems to be working now?
Thanks!
~C
EVERY 3 seconds!!!
Thanks!
~C
