stun server timeout request
Discussion in '3CX Phone System - General' started by abelaguilar, Nov 20, 2007.
  1. abelaguilar
    Nov 4, 2007
    94
    Hello: i'm getting this error:
    19:20:09.015 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 64.69.76.23 has timed out; used Transport: 192.168.0.102:5060
    I dont use a voip provider. I only use a pstn live and my polycom 501.
    Do I need this?? How do I disable?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If all your device are internally, you can ignore this error.
  3. abelaguilar
    Nov 4, 2007
    94
    ok but is it slowing down my network? The reason I ask is becuase in the web management interface under server status the entire screen continues to fill up wih this error and I can't see my other logs becuase the screen moves to fast with this error.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    You can be set longer for "Recheck external IP every (sec)". The default is 1200 sec, may be you can set it to 9999 or bigger.
  5. UdoBo
    Dec 10, 2007
    5
    i have this problem :
    How can i fix this Problem ?
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please refer to this post
    http://www.3cx.com/forums/categories-1/forum-for-specialist-expert-valued-professional-members-3/public-stun-servers-3076/
    Try to use another stun server instead of the default one.
  7. DaveIW
    Sep 17, 2007
    19
    I've been having the same problem for about 3 weeks; so I decided to swap my D-Link Router with a BT Router - set up the same port forwards and - A - VWALA - my lines have requested and everything is usable again..
    I think I'll write that as dud equipment :-(
    D
