STUN server
Discussion in '3CX Phone System - General' started by datacommamerica, Mar 14, 2010.
  1. datacommamerica
    Feb 19, 2010
    7
    Hi Everyboy,
    We are getting STUN request server timed out.
    09:24:59.390 [CM506004]: STUN request to STUN server 193.200.249.2:3478 has timed out; used Transport: 209.160.33.57:5060
    We will appreicate any input.
    Arif
    10,368
    228
    There are many STUN servers available (do a Google search). You can try another to determine if it is a communication or STUN server problem
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Stun.3cx.com is currently is working well, you should give it a try. But my suspicion is router problems. Can you try and ping the server?
