STUNT SERVER
Discussion in '3CX Phone System - General' started by hagesol, Mar 26, 2007.
  1. hagesol
    Mar 26, 2007
    22
    hi
    I have download, and use the 3cx phone system free edition.
    my problem is about STUNT-server, i got this message: ??: from 'hagesol:0/MediaServer':possible firewall problem. Address mapping failed on STUN server 80.239.235.209:3478 for local address ":9000"
    This message come also when i shut down the firewall (f-secure).
    I use Norwegian http://www.Phonzo.no, they dont use stunt server for sip-phone.
    What is my problem?
    Lars
  2. Anonymous
    Anonymous Guest
    Under the advanced settings in the provider configuration have you enabled stun in there?
    By default it is disabled, as it should because you do not use a stun server.
    It also complains about port 9000 which sort of indicates that an internal to external "call" is initated. Perhaps you have an IP phone that is using stun?
  3. hagesol
    Mar 26, 2007
    22
    Thanks for your answare. I dont understand what I have done, but now I get not anymore the stuntproblem...
    now are my problems somthing else...:
    http://www.3cx.com/forums/viewtopic.php?t=1090
    I hope you can take a look...
    I will be very happy if you do..
    lars
