Suggest a soft phone theme for color blind users.
Discussion in 'Ideas' started by FGCUHank, Aug 4, 2017.
Suggest a soft phone theme for color blind users. 5 5 2votes
5/5, 2 votes
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Moving from 11 to 15 and replacing hard phones with soft phones.
    Turns out I have two color blind users that can't distinguish the BLF or status icon colors. Seems the statistic is 8% of men and .5% women. Who knew...
    I know there is not a lot of space there but suggest using a theme with patterns. |||| ///// \\\\\ XXX
