suggestion about new feature
Discussion in 'Android' started by phluisma, Nov 24, 2010.
  1. phluisma
    Nov 24, 2010
    I like this software.
    I am using it in my new Acer betouch e400, it runs nice.
    But I don't want to run the 3cx app each time because sometimes I call to cell phones (it's cheaper with my cell line) and other times to land phones (it's cheaper with voip service).
    I suggest that we use only one "interface", the PHONE of the own ANDROID.... we push it, we dial the phone and when we push the GREEN DIAL BUTTON, we would get a new window asking.... 3CX OR phone call ???
    I have tested sipdroid and skype (android versions) and they work in this way. I think it's better.
    In our software we have only the option "Redirect normal calls – If set, then any calls that you make on the normal dial pad will be re-routed via VoIP if a connection is available" I think we need a new option called ASK&REDIRECT....there we could choose.
    What do you think about this suggestion??
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I agree but feature requests should be posted to http://ideas.3cx.com where they get voted on by other users.
