Suggestions/Assistance on incoming line setup
Discussion in '3CX Phone System - General' started by edujim, May 21, 2013.
  1. edujim
    Apr 6, 2012
    19
    Needed assistance or suggestion on setup
    I have the following:
    3cx v11 SP4, 8 sim calls
    grandstream gxw-4108 - 6 POTs lines
    15 SPA508g's
    This is what I am having problems on how to setup.
    1. How can I get port 6 (line 6 pots) on grandstream to ring on 8 phones.
    2. Show as one of the extension buttons on all 8 phones
    3. Show when line is in use?
    4. Have a different ringtone when a call comes in on that line/ext?
    Could this be auto-provisioned?
    EDIT: Clarification, this is 1 complete solution, not just as individual issues.
    want to be able to get line 6 from grandstream to ring on 8 phones, have a shared line appearance, show busy lamp field, and different ringtone for incoming call on that line.
    Thanks for the help guys!
    Eddie
  2. kristijonas
    Jan 29, 2013
    27
    1. For ringing at the same time - use ring groups.
    2. You'll have to manually edit provisioning template.
    3. Not sure if you can do this
    4. You can select ringtone for each extension in the phone menu, this can also be done in provisioning template.
  3. leejor
    10,375
    231
    You will need to have this line (port 6), set-up as an individual trunk group, in 3CX. that can then be set to ring the extension number that appears on all sets. If BLF works with your sets, you don't require a ring group as it will only be the one extension number.
  4. edujim
    Apr 6, 2012
    19
    leejor
    "when you say set-up as an individual trunk group, in 3cx" this is something that is available in 3cx? I honestly cant see where i would set port 6 up as a trunk group.
    Do you mean convert this POTs line to a SIP Trunk? or Do you mean get another FXO gateway and put that line on it..
    thanks
    appreciate your feedback
    Ed
  5. leejor
    10,375
    231
    If your gateway is capable of being split into two (or more) groups of trunks, then that is what you would have to do. You would then have a trunk group with 5 members, and one with a single member. If it is capable, then it may only be possible if you do a manual configuration, or perhaps you can get away with just a manual config on the single trunk.
    The alternative would be to add a second trunk group using a single line gateway such as the SPA-3102.
