Suggestions on 3CX Bridge Configuration for 12 locations
Discussion in '3CX Phone System - General' started by Michael Menor, Jan 3, 2017.
  1. Michael Menor
    Dec 30, 2016
    43
    We're looking to deploy 3CX for a client with 12 locations. I've looked at the "Connecting Office Bridges" and "Advanced Bridge Configuration" but it only shows three locations bridged together.
    Has any one ever bridged more than three locations?
    Any input/suggestions would be greatly appreciated.
  2. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    Michael:
    You can bridge as many connections as you want. One side will be a master and the other will be slave. Depending on network conditions you may want to use the tunnel for the connections. You just have to work out your outbound rules and network config for having each site dial the other.
    --Tracy
  3. IT Hamster
    May 21, 2015
    43
    Hey Michael-
    Depending on how many endpoints you have at each office location you may be able to get away with using SBC's at each location to handle each site. The latest SBC build allow for up to 250 endpoints (this varies based on how many BLF buttons you plan on using) and you can always add more SBC devices for load balancing at a given site.
