Suggestions
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Sep 20, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    These might help some company's avoid some initial frustrations when evaluating the voice application designer, therefore help increase the number of company's who decide to take on the platform.
    1. In the designer, in any location where the user creating the voice application has to put single quotes around a string, it might be a good idea to validate their string at design time.
    If they put a value in and you can tell it contains non-numeric characters, then throw a warning immediately. It seems the ecmascript error is a common thing until you get used to it.
    2. A "test connection" button would be great, like Visual Studio has. I can tell you guys have already gone to a good amount of detail to make the environment familiar to Visual Studio developers.
    3. When deploying a project, check the web.config file of the IVR for the <httpRuntime> tag so you can throw an immediate warning if you know the size of the project is greater than the value of "maxRequestLength"
    The more errors that can be determined at design time, even if they're just warnings, the better. You've done a great job thus far in general.
  2. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Here's #4
    I just learned after a bit of going around in circles that in your database name, when using a non-standard instance, you have to make sure you escape your backslashes.
    Hence 'TFS2\\SQLEXPRESS' and not 'TFS2\SQLEXPRESS'
    This would be another great thing to tell at design time.
    this would frustrate traditional Visual Studio developers, since escaping characters in strings is always at the code level and you'll never find that in a design time database connection window.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Incrementing version numbers with each build would be great too.
  4. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Thanks for your suggestions, they're much appreciated!
    We'll consider them for future releases.
    In regards to build number, it is currently being incremented in each build. Did you notice any problem with this?
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    ok, sorry I missed that obvious one.
