Suitable Headsets
Discussion in 'Windows' started by joshhough, Dec 8, 2013.
  1. joshhough
    Feb 22, 2011
    72
  2. norekhov
    3CX Support
    Jan 31, 2014
    53
    Jabra and Plantronics headsets are supported with native API since SP3.
    I did not tested exactly this headset but 3CXPhone works with lots of other models and ( theoretically ) should work with any Jabra and Plantronics headset which are supported by their latest drivers.
    Regards, Nikolai Orekhov
    Software developer @ 3CX
