Support for dual internet connections
Discussion in 'Ideas' started by top4, Oct 13, 2017.
Support for dual internet connections 4.3 5 3votes
4.3/5, 3 votes
  1. top4
    Jul 15, 2015
    6
    Almost every instance where we have on-premises 3CX there are dual internet connections. Most of the time both connections have static IP addresses and all traffic goes over the primary connection unless it fails; then everything goes over the secondary connection. We typically set this up in 3CX as dynamic IP's and set the STUN query interval down to like one minute. Unfortunately every time we call in for support they tell us this is an unsupported configuration and that dynamic IP should only be used for testing. I'd like to see a better way of handling dual internet connections.
  2. Silly English Kniggit
    Sep 13, 2017
    220
    89
    Another option is split the routing - SIP 1 over main line, SIP 2 (and all IP required for it) over line 2. Use 2 firewalls and change Windows routing table. That works fine. I've had issues with trying to get the firewall to handle splitting the traffic out. Use authentication and not IP based trunks or you're going to hit trouble.,
