Support for GW with 16,24,32 FXS ports
Discussion in 'Ideas' started by cerifer, Mar 15, 2017.
Support for GW with 16,24,32 FXS ports 5 5 1votes
5/5, 1 vote
  1. cerifer
    Jan 7, 2016
    5
    Dear 3CX:
    Some customer doesn't want to invert in changing ip phones and they want to keep using conventional phones. Also there are mining companies that prefer to use regular phones and use signal regenerator to go into the mine. in earlier versions 3cx supported gateways of brand patton that can support 12,24,32 FXS PORTS. Why was not included those templates in V15 taking under consideration that you already have it?
    regards,
    Cristian Fernandez
    PS.: I already have customer that have equipments with 12 FXO and 12 FXS ports but they are not supported in the version V15
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    www.patton.com/wizard
    There are wizards for 3cx ready to go, I use them regularly.
    (make yourself a free account)
