Support for headset and "Speakerphone" PC Audio
Discussion in 'Windows' started by danrfig1, Nov 14, 2014.
  1. danrfig1
    Nov 14, 2014
    Does 3cxPhone for windows support multiple audio sources? Such as a Bluetooth headset for hands free and PC audio for "speakerphone" capabilities.
    11,086
    325
    The version that I've used allows you to select which device it to "deal" with audio, but, it is not a simple matter of clicking to change. Unless it has changed, you would select, then restart the phone.
  3. norekhov
    3CX Support
    Jan 31, 2014
    53
    You can't change audio device while on a call ( But you can change video device :)
    You can select another device for subsequent calls, restart is not required.
    If you select "handset" as your device 3CXPhone will use it when it's available. Otherwise it will use default windows device.
    Also you can select audio devices separately - ringer, microphone, speaker.
    For example you can have a ringer on your laptop but microphone/speaker can be set to handset.
