Solved Support for SNOM C520
Discussion in '3CX Phone System - General' started by gonzague, Sep 12, 2017.
Tags:
  1. gonzague
    Aug 9, 2017
    5
    Hey guys
    Snom has released a wonderful new conferencing system called C520 :
    [​IMG]
    Is it planned to be supported soon?
    Thanks !
    Mathieu Aras likes this.
  2. Mathieu Aras
    Apr 23, 2017
    would like an answer.
  3. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Hello @gonzague,
    Since the device is coming from a supported manufacturer, it means that at some point the device will be tested from the appropriate department for its compatibility and functionality with 3CX PBX, but at the moment i cannot confirm you that the specific device will be supported for sure.
    Thank you
  4. gonzague
    Aug 9, 2017
    5
    ok thanks
