Support for Snom D715 Phones
Discussion in '3CX Phone System - General' started by MarkS, Feb 11, 2015.
  1. MarkS
    Feb 11, 2015
    14
    Hi, just about to start testing 3cx phone system, thinking of purchasing Snom D715 phones for testing. Does anyone know if these are supported for provisioning, I can see template for Snom 715 (which I believe Snom how now discontinued), would this template work with the D715 ?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Snom D715 are not supported at the moment, kindly follow blog for updates and refer to http://www.3cx.com/support/ for the list of supported devices.
  3. danielcooke
    Mar 18, 2015
    Looks like D715 phones are now supported. At least according to this:
    http://www.3cx.com/sip-phones/snom-710-720-760/
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Yes that's right D715/715 are both supported.
  5. MarkS
    Feb 11, 2015
    14
    Thanks, can confirm the D715 works OK and PnP auto provisioning also works.
