Support for Yealink T46GN
Discussion in '3CX Phone System - General' started by bannerks, May 11, 2014.
  1. bannerks
    Apr 27, 2014
    15
    Hello I want to buy a supported phone for my 3CX and am trying to find out the difference between Yealink T46G and the T46GN.
    Is the T46GN supported and are you aware of the difference signified by the letter G - I have asked Yealink - They have not yet responded but claim in their literature that the T46GN is supported by 3CX.
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    gigabit port... the T46 is supported..
    http://www.3cx.com/sip-phones/yealink-t32g-t38g-t42g-t46g/
  3. bannerks
    Apr 27, 2014
    15
    So i presume the T46GN is also supported or is that not the case?
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,969
    182
    I haven't heard of a GN... I can only imagine it is a regional identifier maybe for the UK...
    I am sure it is supported since the base model T46G is.
