Support for Yealink W60P
Discussion in 'Ideas' started by mamo, Dec 2, 2017.
Support for Yealink W60P 5 5 7votes
5/5, 7 votes
  1. mamo
    Aug 22, 2016
    35
    Yealink has a new DECT phone called W60P. It seems very similar to the older W56P. In fact the handset is exactly the same.The only difference seems to be that the base now supports up to 8 handsets and also 8 calls, while W56P is limited to 5 handsets and 4 calls.
    Because of the similarity compared to the older and already supported W56P, it probably should be very easy to get this running with 3CX. It might even already work without changing anything, just using the configuration for the old model?
    Can someone confirm that it does already work, or give information if / when it will be supported?
  2. DDSAg09
    May 23, 2017
    I would also like to know, I'm considering the purchase of one vs. the older W56P.
  3. Miggidy
    Jan 29, 2018
    Also interested in support for this
  4. jem1
    Aug 29, 2012
    78
    30
    The 15.5 SP3 Beta has a yealink W60B (for the base) in the FXS/DECT Section
  5. Decoratinglife
    Feb 5, 2018
    5
    Sorry to break from the idea, but is Yealink W60P good?
  6. netswork
    netswork Active Member
    Mar 11, 2011
    577
    it shows to be supported in the latest update. There is an option for Yealink w60B....I assume a typo
  7. it122
    Nov 12, 2012
    It think the way it works is W60B is the base station H is the handset, and P is the phone itself.
