Support of D-LINK DIV-140
Discussion in '3CX Phone System - General' started by jiquintero, Jun 25, 2008.
  1. jiquintero
    Jun 25, 2008
    I would like to know if somebody in the forum has tested the D-LINK DIV-140 with the 3CX version 5.1?
    Thanks in advance
    JIQ
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    It should be a not supported gateway for 3CX ........
