"Support 'Replaces' header" and "Supports Re-Invite?
Discussion in '3CX Phone System - General' started by pacpac, Feb 19, 2012.
  1. pacpac
    Jan 12, 2012
    73
    Hi, I have connected PAP2T ATA to 3CX. On the extension, do I need to check or un-check "Support 'Replaces' header" and "Supports Re-Invite"?
  2. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    I implement these with both checked.
    Mark
  3. pacpac
    Jan 12, 2012
    73
    Hi, with these two boxes check (also only 'Supports Re-Invite') I am not able to get audio when calling extension to extension. Ref my other post; http://www.3cx.com/forums/no-audio-ext-ext-dialing-25718.html
